RDC6445G controller failed to load the panel when turned on
EDCE79BA
The control system used for my device is RDC6445G. Today, I found that the panel loading was abnormal and I was unable to enter the main interface normally. There is no cursor flashing on the screen, as if the system is not responding. No matter how you press the button, the interface remains still, as if stuck in the startup process. Any ideas? Thanks in advance!
Antwoorden (2)
  • 0B5DC9F3
    I have encountered this issue before, which is due to a program error or a faulty microcontroller, requiring the program to be burned again
    • ok
  • Check if the wiring connecting the controller motherboard and display screen is loose or poorly connected while the power is off. I have had a similar problem before, which was ultimately caused by a wiring malfunction. If possible, re plug and unplug the ribbon cable to ensure a secure connection.
