Omtech K40+
HJ72X00U
I try to connect my new Omtech K40+ but it is not recognized by the software. Driver is install and K40+ run on Lightburn withot problem. Whay should I do?
Antwoord (1)
  • What is the controller model and is the driver name recognized as USB Serial Converter in the device manager? You can try manually adding and modifying USB port connections
    • Hello and thank you. How can I see which controller is installed on my machine?
      • Jesson
        Auteur
        Hello, this requires contacting the machine manufacturer
