How to solve the problem of RDC6332NM controller not resetting to the origin?
634D6613
My CO2 laser cutting equipment uses the Ruida control system, model RDC6332NM. Today, I started processing normally, but found that it cannot be reset to the origin. Can anyone help check? Thanks!
Antwoorden (3)
  • Thomas
    Try resetting the z/u axis to remove the enable and see what happens?
    • Reset is normal, thank you
  • I suggest you check if the machine's size and step distance settings are correct, and also check if the limit is normal
    • Step distance setting is not a problem
  • Check if the zero return direction setting is correct. If the direction setting is reversed, the machine will return to zero in the opposite direction and will never touch the origin switch.
    • OK, thanks!
