We do not need to count or distance to be true as we manual feed throuh the software or keypad. Pity we can't set the size to 0mm or have a function with manal feed, no count. the material roll normaly is longer than 30Meter.
How can I increase the length of U- Feed belt or not to count the meters as I can only get about 4 full rotations of the U-feed belt when cutting long rolls of material. I then have to press reset every time before i can continue. On a RDC6685U-DFM
Hello, you can increase the length of the U axis in the factory settings.
Hi Blue sea,I have done so. the max setting is 10 000mm. If i could set the belt length to 0mm will the manual feed still work? Unfortunately the factory revert back to 2mm.
Hello, please check your manufacturer's parameter settings, has the U1 axis been reset?
