Geaccepteerd antwoordI got it working by Plugging U1 to U2. All Seems to be working Well.
I am using RDUnion software to configure the sustem, but can't get U-drive to work in Dual beam.
I would apreciate if anybody can help.
This is most likely because the dual-beam mode is occupying the physical output channel corresponding to the U-axis (typically an analog voltage output to the galvanometer), leaving no output path for the U-drive signal you originally used to control the external motor.
First, ensure that dual-beam mode is properly enabled at the hardware level, not just checked in the software.
Check the configuration file: Make sure you are not using a CFG file intended for single-beam mode. In the RDUNION software, open your configuration and check the “Port Configuration” or “Scanner Configuration” settings.
Typically, you need to set it to “Dual-Head Stitching” or “Dual-Head Interconnected” mode. In dual-beam machining, you generally use “Dual-Head Stitching” mode (where both heads process different parts of the same large-format graphic) or “Dual-Head Asynchronous/Interconnected” mode (where both heads process different content).
XY-Axis Mapping: Verify that the XY-axis output ports for the first galvo (typically the primary head) and the second galvo (secondary head) have been correctly assigned. For example, the primary head uses X/Y, while the secondary head uses U/V or the second set of DAC outputs.
If you must use U-drive in dual-beam mode, you need to confirm that the control card has spare pulse axis interfaces (such as stepper motor pulse ports) to perform the U-drive function, rather than using analog signal channels. Please check your hardware wiring: ensure that the U-drive control signals are connected to the correct pulse ports, rather than the analog ports occupied by the galvanometers.
Thank you everybody for all the help I got to fix the problems so far. Every awnser helped me.
We had it set to Dual Cantilever before and the U-Drive was working perfect. Then a Ruida Engineer change the configiration to Dual Beam. Since the change over, the U1-drive would not work.
