What could be causing files to not appear in the controller's memory after a successful transfer?
83D44392
Problem Description:
  • When I send a file from my PC using RDWorks software to the controller, the transfer appears to complete successfully, and RDWorks displays a "transfer successful" message.
  • However, when I check the file list on the controller's HMI (Human-Machine Interface), the transferred file does not appear.
  • Additionally, I am unable to run files directly from the HMI. Sometimes the "Start/Run" button on the HMI is unresponsive.
  • When I run a file directly from RDWorks (online mode), the machine operates normally without any issues.
Questions:
  1. What could be causing files to not appear in the controller's memory after a successful transfer?
  2. Why might the HMI "Run" button become unresponsive?
  3. Is it possible to format or reset the controller's memory to resolve this issue?
  4. If a firmware upgrade is recommended, could you please provide instructions or a link to the appropriate files for the RDC6442S model?
System Information:
  • Controller Model: Ruida RDC6442S
  • Software: RDWorks (please specify version if known)
Antwort (1)
  • Hello, based on your feedback, the following suggestions are made:
    1. Check if there are too many files stored on your controller panel, and format the controller memory.
    2. Check whether the file format is supported by the software; you can replace a graphic file to test it.
    3. Replace the HMI panel and test to see if there is a similar problem.
    4. Replace an HMI connection cable.
    5, Download the latest software program, you can log in to my official website to download.
    6. If you need to update the controller firmware, you need to provide the existing controller firmware version number and HMI version number.
