Akzeptierte AntwortYou can install two copies of the software on your computer, selecting different storage drives for their installation directories, and then create clearly labeled shortcuts on the desktop. One copy can be configured with the machine origin set to the left, and the other with the machine origin set to the right, allowing you to use them interchangeably as needed. Currently, switching the machine origin for processing by modifying the IP address is not supported.
