RDC6445S: Multi-object cutting misalignment when using dual-head independent offset
F9573047
How to avoid misalignment when cutting multiple virtual array elements? My controller is RDC6445S
Antwort (1)
  • 1. Set the dual-head spacing — verify the distance between the two heads.
    2. Reset the Z-axis — ensure it is also homed along with X and Y.
    3. Verify interlocking mode — after homing, use the panel buttons to jog the machine. Watch the X and Z coordinates — 4. if they move together, the Dual-Head Interlocking Mode is working correctly.
    5. Reconfigure the job — set up a new virtual array pattern and run a test cut.
    Note: The most likely cause of the misalignment is that the Dual-Head Interlocking Mode was not activated properly.
