Akzeptierte AntwortPlease refer to the following suggestions for troubleshooting:
1. Export the RD offline file that triggers the error and submit it to our after-sales technical team for analysis.
2. Ensure the RD offline file name contains only 4 characters (alphanumeric, in English or Chinese) and does not include any special characters.
3. Please double-check the motherboard model, as file compatibility may vary between different motherboard types. For example, an RD offline file generated for a 6442 motherboard cannot be copied to a 6445 motherboard's memory.
4. Import the offline file into RDWorks V8 to verify whether the software can preview and load it properly. This step is to confirm that the offline file is not corrupted.
5. Try using a different USB flash drive.
6. Ensure that the number of laser heads configured in RDWorks V8 matches the actual hardware when generating the graphics.
Thanks
