The first pixel does not connect properly on the RDC6555G control card
M@A@G@A
When I was using the machine for machining today, I couldn't connect the first point. Is this due to hardware not being properly connected? seek help! I am using the RDC6555G control system.
Antworten (3)
  • Clarence
    Check if the server response parameters are set correctly
    • I adjusted the servo parameters and everything is now normal
  • Is the axis response speed synchronized?
    • yes
  • Check if the step distance is correct
    • The step distance is correct
