Secondary positioning error of RDC6612U control system
I've encountered a new issue with my equipment. The control system is RDC6612U, and an error occurred during the execution of the secondary positioning program, resulting in a significant deviation between the final positioning result and the expected target coordinates. Who can guide me? I would be extremely grateful!
Antworten (3)
  • John Trant
    1. By increasing the matching timeout and stabilization time to optimize and give the camera more stable dwell time, the camera can ensure stable and accurate recognition of the identification; The position of the Mark point can also be placed as close as possible to the middle position of the identification mark to reduce the distance of secondary positioning.
    2. Simply readjust the identification mark to the position where both the camera and the moving axis reach simultaneously.
    • I increased the matching time and stabilization time, and now it's normal
  • It is likely that the matching timeout or the stability time is too short
    • Yes, I increased the matching time and stabilization time, and now it's normal
  • In this situation, I usually turn off the power and restart it, and then check for related mechanical problems
