Akzeptierte AntwortHave you set the origin offset? Origin offset needs to be enabled in order to use this feature properly
The first time I operated the Ruida control system, model RDC6612U-DFM, all other settings and operations were normal. However, when the system was performing the "two end separation" machining function, an exception occurred and it was unable to be processed according to the preset program.
Confirm whether your device supports the "two end separation" function, that is, whether it has independent working "camera end" and "host end".
I have enabled the origin offset, and it's working properly now. Thank you for your answer
