RDC6332M, Why doesn't the Z-axis motor move when pressing the Z button on the operation panel in manual mode?
52C81B44
My device is equipped with the RDC6332M control system. Today, I debugged the device and the system switched to manual mode. I pressed the "Z+" button on the panel, thinking that the workbench would slowly rise, but the device did not respond; Press the "Z -" key again, but there is still no response, and there is no sign of the Z-axis motor rotating. Has anyone encountered such a problem? Can you help me? Thank you!
  • Some people may overlook the question of whether the Z-axis function has been enabled. Many machines actually only connect X/Y, and although the motherboard has the Z-axis function, the manufacturer has not enabled it. So, first confirm if the Z-axis is enabled. If it is not enabled, the buttons will not have any action.
