I used RDC6612U-DFM to cut the cross out of alignment
DDminaj
My machine is equipped with the RDC6612U-DFM control system. After calibration today, the cross I cut still did not align properly and showed offset. What should I do?
Antworten (3)
  • Clarence
    Sing the following two parts together
    1. Check if the step distance of the machine is correct.
    2. The camera is not securely installed, causing it to shake during movement.
    • I have checked and found that the camera is shaking. I have reprocessed it and everything is normal now. Thank you
  • Check the reasons from the core aspects of machinery, parameters, calibration, and materials
  • Have you conducted repetitive testing? Cut the same cross line pattern 2-3 times in a row. Is the observation of misalignment completely random, or is it the same every time in the same position and direction?
    • Almost at the same location
      • Gilbert
        Autor
        The problem is likely to be systemic, such as mechanical errors, incorrect parameter settings, or inaccurate calibration.
