Why is the Y-axis power weak for RDC6555G controller?
0DB765FD
My device is equipped with the RDC6555G control system. I am preparing to cut the workpiece, but I found that there are significant differences in the cutting effect of the device in different directions. When the shape is cut along the X-axis direction, the laser power performs normally, the material can be smoothly cut through, and the incision is also relatively uniform and flat. However, when the device moves along the Y-axis direction for cutting, the laser effect is significantly weakened, and under the same power parameters, the material may experience continuous or incomplete cutting. I can't understand this phenomenon, who can help me? Thank you.
  • Matthew
    It should be an error in the encoder resolution setting. Please reset the encoder resolution parameter
  • There may be inappropriate motor settings in the RDC6555G controller, such as low current settings, low driving voltage, etc., resulting in insufficient power on the Y-axis.
    resolvent:
    Enter the parameter setting interface of the controller and check the Y-axis motor current setting.
    Ensure that the Y-axis current setting is the same as the X-axis, or adjust the current output according to the motor specifications.
    Check the voltage setting of the Y-axis drive to ensure it meets the requirements of the motor.
