RDWelderDW-V2Pro laser handheld welding system does not blow air
84B91763
My laser handheld welding system is RDWelderDW-V2Pro. During use, I found that the blowing function was not activated as expected during the welding process. I checked that the equipment settings were correct and the gas source was normal. The welding gun did not provide airflow. What is the reason for this problem? Who can answer me? Thank you.
Ответы (3)
  • Howard
    Have you installed the relay? Please check it
    • I installed the relay and it worked fine now, thank you
  • The blowing function is controlled by an air valve or solenoid valve. If the valve is damaged or the circuit is abnormal, the airflow cannot be output. You can check whether the valve is stuck or damaged in the event of a power outage.
  • Check the machine settings to see if the gas blowing function is disabled in the operation settings. Additionally, inspect the gas outlet of the welding gun or welding head for any material or impurities that may be blocking the gas flow.
