Принятый ответIf the "excessive following error" alarm is frequently triggered during the cutting process, the maximum following error parameter needs to be increased. You can try it.
My fiber laser equipment uses the RDV6563FG control system. Today, I was operating normally for processing, but I found that the cutting head had a large following error. During the operation of the equipment, the cutting head did not respond in a timely manner when following the height changes of the board, resulting in a significant deviation between the actual height and the set height. How should I adjust? Thanks in advance!
It may be a problem with the motor. Check if the power supply voltage and current settings of the motor are correct to ensure stable operation. If there is abnormal noise and excessive heating during the operation of the motor, it may be a motor malfunction and the motor needs to be replaced.
Yes, I increased the error parameter and it's normal now
