Принятый ответIt may be that the. net environment file is missing or damaged. Try reinstalling the Windows system or reinstalling the. net environment
The controller used in my machine is the Ruida RDV6555G. When performing vision-based positioning machining and activating the Mark point matching function, a pop-up window displays C++ garbled characters. What could be causing this? Any ideas?
Ensure that the software and firmware of the control system are the latest versions. If the software or firmware version of the system is older, it may not fully support the character set required for visual matching markers, resulting in garbled characters
After reinstalling the. net environment, the error disappeared. Thank you
