RDV6555G control system scanning shows ghosting
9F134964
I have a laser cutting machine that uses Ruida's control system, model RDV6555G. Today, I noticed a ghosting during scanning, where the same straight line seems to have been traced twice, with slight misalignment on both sides, especially during high-speed scanning. How should I adjust? Thank you all!
  • Caspar
    Adjust the reverse clearance parameter
  • The display ghosting during scanning is usually caused by a malfunction in the monitor or connection cable.
    Display driver circuit failure, resulting in loss or interference of display signals, leading to ghosting.
    There may be hardware issues with the display screen, such as uneven backlighting and damaged pixels.
    Signal transmission interference or poor contact can result in incorrect image display.
