RDV6445G controller calibration failed
A08E1C02
Hello everyone! I am adjusting the CO2 visual cutting equipment, and the control system is RDV6445G. During the calibration process, the equipment cannot respond correctly to the set parameters, causing the system to fail to complete the expected adjustments. I checked the connecting cables and sensors and confirmed that there was no physical damage, but the calibration still failed. I need help, thank you!
  • F619E49D
    Please check if the corner positions are reasonable and if there are any omissions
    • There is an issue with the corner points, which has been resolved. Thank you
  • The calibration process requires all hardware components to function properly, and any connection issues may result in calibration failure.
    1. Check the connection of the stepper motor: Ensure that the motor cable is not loose or damaged.
    2. Check sensor connection: Ensure that the position sensor or laser head sensor is functioning properly and connected correctly.
    3. Check the power supply: The power supply voltage is stable to avoid controller malfunction caused by unstable voltage.
