Принятый ответThe function of not lifting the knife has not been turned off, right? I have made this mistake before
RDD6616U vibration knife control system, I think I operated something wrong, the tool cannot be lifted during the cutting process. What should I do if the tool remains pressed down and cannot be lifted according to the program instructions, whether it is wrapping or moving to a non cutting area?
I think it may be a problem with your pneumatic system or motor drive. The lifting of vibrating knives usually relies on cylinder or motor drive. If the air source pressure is insufficient, the air path is blocked, or the drive motor is damaged, the tool cannot be lifted. It is necessary to check whether the air source pressure is normal, whether the air pipe joint is leaking, and confirm the working status of the drive motor.
You're right.
