RDD6616 control system V axis no action
Simon Praschl
My RDD6616 control system does not produce any movement of the V-axis motor during the execution of the machining program. I checked the power supply and it is working properly
Ответы (3)
  • Ignativs
    What drive are you using? If it is a Rexroth driver, there are 24V and 5V drive signals, and the motherboard sends out a 5V drive signal. Don't choose the wrong one
    • Oh, I see. I reconnected the 5V signal and now it can function normally
  • Your problem is usually caused by the following reasons
    1. Wrong connection of motor wire
    2. The motor does not support split wiring
    3. Damaged motherboard port
  • Check the motherboard ports for damage and ensure that the motor wires are properly connected
