RDC8445S repeated communication issues
AIDAVIL
Hello everyone,
I’m reaching out to the community for a technical perspective, as I’m facing a recurring issue and have not yet been able to identify the root cause.
Here is a clear summary of the situation:
  1. I initially used a Ruida RDC6445G, which worked correctly for a period of time, but later developed serious communication problems with the PC.
  2. After that, I purchased another Ruida RDC6445G from AliExpress.
    This unit never communicated with the laptop, regardless of the method used (LAN, USB, or WiFi).
    A dispute was opened and the controller was returned to the seller, but AliExpress closed the case without issuing a refund, based on their internal resolution process.
    The final outcome was that the controller was returned and the payment was lost.
  3. Assuming this was an isolated incident, I recently purchased a Ruida RDC8445S from eBay, but I am now facing exactly the same communication issue.
What I have tested so far:
  • two different laptops
  • multiple versions of RDWorks
  • LAN, USB, and WiFi connections
  • basic wiring and system settings verification
The controller powers on, displays menus normally, and appears to function locally, but no software connection can be established (constant “Connection Failure”).
My questions for the community:
  • are there any essential configuration steps that are easy to miss?
  • have you encountered similar issues with RDC6445G or RDC8445S controllers?
  • are there any known production batches with communication problems?
  • could this be a firmware or hardware compatibility issue that is not immediately obvious?
I am not looking to assign blame. My goal is simply to understand whether this is a configuration issue, a compatibility limitation, or a hardware-related defect, before continuing with further testing or purchases.
Any feedback or shared experience would be greatly appreciated.
Thank you in advance!
Ответы (3)
  • blue sea
    Hello, which version of RDWorks V8 software are you using? The RDC8445S controller only supports software version 8.01.68 for communication. Software below this version cannot communicate. You can log in to our official website: https://www.rdacs.com/en/download?type=software to download the latest RDWorks software for installation and communication. Thank you for your support!
    4
    • Hello, Yesterday I discovered this myself through direct experience, after many other attempts and tests on different laptops. You were right — communication works only with RDWorks version 8.01.68 or newer. Thank you very much for the clarification and for your support. I would also like to ask you one more question: Does LightBurn work properly with the RDC8445S controller? If yes, is there a specific firmware version or configuration required? Thank you again. Best regards, Ghiță
      • blue sea
        Автор
        Hello, since LightBurn is not our company's controller-compatible software, you can try to see if it can be matched, it has nothing to do with the firmware version of the controller, we suggest you use our company's compatible software RDWorks 8.01.68 for communication, thank you for your support!
      • AIDAVILответblue sea
        Thank you!
  • софт RDWorks 8.01.68 не помогает
  • вы не один, в этом вопрсе...
    у меня проблема не решена....
