Принятый ответI suggest you check the following items:
1. The software manufacturer's parameter for enabling motor reset is not activated
2. The panel button function is damaged
3. User parameter power-on reset is not enabled
My co2 cutting machine has been upgraded with the Ruida control system, model RDC8445S. When I press the reset button, there is no response. What could be causing this? Help!
First, inspect the button itself for any damage, wear, spring failure, or stuck internal mechanical structure. Then, check the wiring for correctness.
The reason is that the power on reset enable was not turned on, but after it was turned on, the panel can now be used normally
