Ignativs
Принятый ответ
Принятый ответUsually, the motherboard memory files are damaged, the controller cannot find the correct data, or you copied illegal files into the motherboard through a USB drive.
It's really puzzling. My device is using Ruida's RDC6612U controller, and the HMI pop-up file is not compatible. I checked the firmware version and it's not a problem. What should I do next to solve it?
You should first verify the correctness of the file format
Thank you, I have already resolved it and everything is normal now.
