Принятый ответHave you connected an external stop button? If the stop button is normally closed, it needs to be changed to a normally open button
The laser cutting machine uses RDV6555G, and the reset fails. My cutting machine is equipped with the Ruida control system RDV6555G, but the reset fails. When resetting, the panel flashes briefly and there is no response. Is there anyone who knows more about it? I hope to get your help. Thank you!
Have you checked the power supply? Try using a multimeter to measure whether the output voltage of the power module is stable at the rated value.
Check the firmware, it may be caused by incompatibility
Oh, I understand, I have replaced it. Thank you for your guidance
