The double head spacing of the format is less than the projection range. Please change the format settings
When I use VCutWorks for dual-head mutual shifting cutting projection and perform full-format cutting on the calibration block, the program prompts a "border out of bounds" error. Is anyone familiar with VCutWorks? Any suggestions would be greatly appreciated.
Please check your workpiece size settings, the sheet size is smaller than the actual required movement space for the tool path.
Okay,thanks
