Using Ruida to control dual Y-axis
A2B44711
Could anyone advise which Ruida controller supports dual Y-axis operation and is compatible with LightBurn? I have a CO2 laser system equipped with two closed-loop encoder motors on the Y-axis, and I'm looking to set it up with a Ruida controller.
Thanks in advance!
Odpowiedź (1)
  • hi dear just take two signal  wires from the controlles cards of Y axis  and gives signal to 2 Y drives this will work both drives
    Bhupen
    • thanks!
