RDWelder-SW handheld welding system cannot be connected properly
C7DF2D5C
When I was operating the RDWelder-SW handheld welding system, the device was unable to connect properly. After turning on, communication cannot be established between the control panel and the welding machine host, and the system repeatedly prompts connection failure. At the same time, when attempting welding operations, it was found that the laser had no light reaction at all. Whether checking the status of the emergency stop button or restarting the device, the problem still persists.
Odpowiedzi (3)
  • Adrian
    Check according to the following points
    1. Is there a mismatch between the board version and the panel version.
    2. Check if the HMI panel wiring is correct.
    3. Check if the focusing lens of the gun head is damaged.
    4. Check if the protective lens is dirty.
    5. Check the red light offset parameter and whether the red light emits light
    • Thank you for your response
  • Check if the focusing lens of the gun head is damaged and if the protective lens is dirty.
    • Thanks
  • Insufficient or unstable power supply of the device may cause connection failure, especially when connected wirelessly, and low battery power can also affect performance.
    • I have resolved it, thank you
