Payson
Zaakceptowana odpowiedź
Zaakceptowana odpowiedźEnter User Parameters - Other Parameters, check if automatic vibration and adsorption are enabled.
It's strange, my RDD6616 vibrating knife doesn't automatically activate vibration and suction during processing. Is this set up incorrectly? Or is it a hardware issue? Is there anyone enthusiastic to answer? Thanks!
This should be an issue with the software settings
I see. I should have thought of this reason earlier. Thank you
