Zaakceptowana odpowiedźIf an error occurs during Z-axis reset, a system reset error will be displayed, which may be caused by the following situations:
1. When performing the reset motion, the motor did not move or moved too slowly, resulting in timeout exit.
2. It may be due to the incorrect polarity of the motor movement, which triggered the lower limit switch during reset and caused the reset to exit.
I followed your steps and now everything is normal. Thank you for your reply
