My RDC6332NM controller preview file shows' no connected device '
634D6613
My CO2 cutting machine uses the RDC6332NM controller, and when previewing the file, the HMI pops up "No Connected Device". Is there a problem with the link between the device and the controller?
  • Thomas
    I suggest you check the following items:
    Is the communication panel cable reliably connected?
    2. Hardware malfunction, communication chip damage (possibly on the motherboard or panel side)
    3. The memory file of the motherboard is damaged, and the system cannot find the correct data, resulting in this prompt. Exclude by formatting and re downloading
    • I have resolved the issue caused by the failure to connect the numerical multi controller and HMI. Thank you
  • Confirm whether the driver program of the controller is installed correctly. You can check in Device Manager for any yellow warning signs indicating driver installation issues.
