My RDC6332NM control system cannot engrave in RDWorksV8
Liam
My equipment uses the RDC6332NM control system, which allows for normal cutting. However, when I use the engraving function in RDWorksV8, it does not execute properly. What could be the reason for this? Have I overlooked any settings?
Odpowiedzi (3)
  • roy
    The 633X series cards are equipped with non-metallic height adjusters, so the engraving function is generally not enabled by default. It is necessary to enable the engraving function in "Manufacturer Parameters=>Special Parameters (Password RDTSMM)" before use.
    • Oh, I see. I can use it normally now. Thank you
  • I suspect that your RDWorksV8 version is incompatible
  • I think it's an issue with the parameter configuration file, which needs to be matched with the configuration file of your control system model
