Geaccepteerd antwoordHello! Multiple positioning point settings have been set on the panel, reset to 'No'.
After I turned on the CO2 cutting machine, the RDC6332NM control system seemed to be functioning normally. However, when setting the positioning point before processing, a problem occurred. No matter how I moved the working head and tried to save the current position, the system would not recognize it as a valid positioning point. After starting the program, the equipment still returned to the default origin point. I repeatedly checked the relevant settings and couldn't find the reason. Who can guide me? Thank you!
Ensure that the servo enable (Servo On) signal of the servo drive is valid. Without activation, the motor is in a free state and will not respond to positioning commands.
The positioning point is not equal to the starting point of the machining process. The positioning point only saves coordinates and cannot automatically become the machining origin
thanks!!
