Geaccepteerd antwoordThis post provides a detailed introduction, I suggest you refer to it:
https://www.chanelink.com/community/post/3887
Today, I used CO2 laser cutting equipment to process workpieces. The control system is RDC8445S. After starting, the cutting head ran normally, but there were obvious uncut areas on the edges of the cut sheet, especially concentrated in the curved areas. I have checked the power, auxiliary gas pressure, and nozzle status, and they are all within the normal range. What further checks do I need to do?
Try increasing the power?
thank you!
