Geaccepteerd antwoordFor me, testing is always the most important thing. Every type of wood behaves differently, and honestly, even wood from the same tree can vary a lot in density and moisture. Just because a test worked on one piece a month ago doesn’t mean it’ll work again today. I almost always do a quick test before committing.
I’ve also played around with different lenses. To be honest, I haven’t seen a huge difference between them. My newest CO2 machine came with a 1.5" lens, but compared to my usual 2.5", it didn’t suddenly change everything. At least in my experience, lens choice hasn’t been a game changer.
I do tweak speed and power, but they’re not as critical once you have enough power to begin with. That’s a big difference compared to low-power diode lasers, where settings matter a lot more. If I’ve got plenty of time, I’ll run slower speeds and lower power. If I’m in a rush, I just crank things up and move on.
On my 100W CO2 machines, a common setup for me is around 400 mm/s at 30% power, or 1000 mm/s at 60%. I also own higher-end CO2 lasers that can technically run several times faster than cheaper mass-produced machines, but honestly? I almost never run them at full speed. I don’t think I’ve ever actually maxed one out, lol.
Focus adjustment is another underrated trick. My machines have autofocus, but I tried it once and never bothered again. I prefer dialing it in manually. I’ll focus perfectly for fine detail work, or intentionally go a little out of focus for general jobs. I can’t even remember where I first learned that — probably YouTube — but it’s been super useful.
Fiber lasers are a whole different beast. I’ve been running mine for about 18 months now, and setup takes way more effort. You’re adjusting speed, power, and frequency, and changes actually make a noticeable difference. For example, when engraving slate, lower power gives me a lighter result, while higher power turns it more brown. At least that’s how my machine behaves. Even after a year and a half, I still feel like I’m learning something new with fiber.
