If a laser type that does not match your actual use is selected in RDWorksV8, the controller may mistakenly send a start signal when turning on, causing the laser to automatically emit light.
When starting RDWorksV8 software, the system encountered an abnormal phenomenon: the laser equipment often automatically emits light after startup without any operation instructions. Although the device displays normally, the laser needs to be manually turned off every time it is turned on. This issue must be resolved. Thank you for any suggestions!
This post should be helpful to you, you can refer to:
