There is an issue with the X/Y axis during the power-on reset of RDC6445G
E419D846
I have a CO2 laser cutting system equipped with an RDC6445G control system. During the power-on reset, I noticed an unusual situation: the X-axis quickly hit the limit switch and stopped during movement, while the Y-axis continued to move towards the origin at a very slow speed, far from completing the reset. I really don't understand why this is happening. Can anyone help me? Thanks in advance!
Antwoorden (2)
  • 7760F7A1
    Check if the limit switch is broken, this is the most direct cause.
    4
    • The limit switch was faulty, and I replaced it with a new one. Thank you
  • The limit switch has been replaced, which is the most common. In addition, the polarity in the Y-axis direction has been reversed. Simply reset the polarity.
    • The limit switch is faulty. Thank you for your suggestion
