Geaccepteerd antwoordThe imported graphics are automatically grouped. In the settings window, find the "Auto Group" option and uncheck it.
I don't know if anyone else has encountered this problem. When using RDWorksV8, I found that the graphics bridge function is not fully displayed. The complete graphics bridge position and parameter setting interface should have been displayed, but only partial content was displayed, and some buttons and options could not be loaded or displayed properly. How to solve this problem? Thank you!
1. Problems with the graphics themselves
If there are unclosed contours, repeated line segments, or breakpoints in the original shape, the bridging calculation will be abnormal, causing some bridging to fail to generate or display incompletely.
2. Improper setting of bridging parameters
Setting the bridge spacing, length, or quantity too small/too large may prevent the software from correctly allocating bridge positions, resulting in missing positions.
