RDV6563FG-NET, A-axis reset failed, what should I do?
Amanda
My control system is RDV6563FG-NET, and the A-axis reset failed. I don't know the reason, and someone told me it was a problem with the motor driver parameter settings. Do you have any ideas? Thank you all.
Antwoorden (3)
  • Williams
    It may be due to poor limit contact
    • After replacing the limit switch, it is now functioning normally
  • After turning off the power, try to slowly rotate the A-axis by hand. Does it feel smooth?
    • Yes, smooth
  • I suggest you check the following two items: motor wiring and motor driver parameter settings
