John Trant
Geaccepteerd antwoord
Geaccepteerd antwoordDxf format versions above version 04 are not compatible. I suggest you change the drawing format and use the second channel to open the DXF format file
Please forgive my poor English. Simply, I use RDV6555G, it will disconnect when replacing the DXF format drawing. help me please.
I have solved it, thank you for your answer.
