My RDWelder-SW handheld welding system does not blow gas
Hannah
I've encountered a new issue with my RDWelder-SW handheld welding system. I was in the middle of a job, and everything else was functioning normally, but I noticed that the shielding gas was not being supplied properly. What could be the reason for this?
Antwoorden (2)
  • Patrick
    The system blowing signal to the solenoid valve requires the addition of a relay. You can try it out
    • Okay, I installed the relay and everything is normal now.
  • Suggest checking the connection problem of the gas supply system, which may be caused by bent or blocked air pipes
    • There's no problem with the gas channel. I added a relay and it's now normal
