John Trant
Geaccepteerd antwoord
Geaccepteerd antwoordPlease check if the driver cable is wired correctly and if the driver control mode is set correctly
My laser engravers use the RDC6332NM controller, but today I encountered a strange issue during operation: the machine only moves in one direction. Could someone please help me? Thank you.
This situation is generally not a hardware malfunction. You can first check if the drive wiring is correct
I set the driver to dual pulse and changed it to pulse+direction. The problem has been solved. Thank you for your reply
