I am using the RDC6585G, but the panel failed to read the file
Liam
When I was operating the RDC6585G control system and reading files on the panel, after about 30 seconds of operation, the screen prompted "Communication failure" and data transmission failed to complete. Can anyone help provide a solution? Thank you!
Antwoorden (3)
  • Payson
    Check if your panel matches the motherboard product model (model, firmware, non-standard)
    • After reading the motherboard information, it was found that the model did not match. Replace the corresponding panel to restore normal operation
  • Check if the communication cables between the panel and motherboard are functioning properly, and if the ports are securely plugged in?
    • I replaced the communication cable, but the problem still persists
  • Check in RDWorks: Open file → Simulate run → Ensure graphics and paths are correct
