Why can't the RDC6445GZ-DFM-RD template file be displayed?
C33DF9A3
RDC6445GZ-DFM-RD control system, when I opened the template file, the interface did not display the corresponding graphic content, and the template list was empty. Is this due to file corruption or some other reason?
  • Jerome
    Your template path may be incorrect. The default saved path is in the model folder in the visual directory. Please reload it. In addition, after saving a certain number of templates in a folder, a new folder can be created to save the templates and avoid template loss.
    • The problem has been resolved, thank you for your answer
  • It may be a compatibility issue between your RDWorksV8 version and the control system, which may cause template files to not display correctly. It is recommended to download the latest version of RDWorksV8
