What is the maximum machining speed of the RDC6445G controller?
E419D846
My CO2 laser cutter is equipped with the RDC6445G control system. I'd like to test how fast it can cut thin materials at maximum speed. If anyone knows the answer, please let me know. Thanks!
Antworten (3)
  • Ruidatech5
    The controller itself (RDC6445G) does not define the real cutting speed limit. The machine mechanics, laser power, and material determine the actual maximum cutting speed.
    For very thin materials (paper, thin plastic, thin wood ):
    • 200–400 mm/s → common fast cutting
    • 400–600 mm/s → possible on high-quality machines
    • >600 mm/s → rare; usually engraving speeds
    • i m using  250 speed and power 11%  250 for engraving  mdf (5mm)
      If engraving is too dark
      i try:
      • Speed: 300 mm/s
      • Power: 9–10%
    3
    • Your answer is detailed and professional, which is very helpful to me. Thank you
  • Hello! the maximum speed is 3000 mm/s
    3
  •  I have got the same problem.
