Using the RDV6563FG control system, the laser triggered an alarm
1C2920B1
I have a fiber laser equipment equipped with the RDV6563FG control system, but the laser emits a rapid alarm sound. The screen is flashing and indicating an abnormality, and the beam is interrupted. I tried resetting but it still didn't work. What should I do? Thank you for any suggestions.
  • Adrian
    Check whether the laser power supply is stable and the voltage is normal. Power fluctuations or unstable voltage can prevent the laser from operating properly, thereby triggering an alarm.
    Next, check the power connections to ensure the power cord is securely plugged in and that the power outlet is working properly.
  • Most likely it is a power issue
