Akzeptierte AntwortCheck according to the following points
1. Is there a mismatch between the board version and the panel version.
2. Check if the HMI panel wiring is correct.
3. Check if the focusing lens of the gun head is damaged.
4. Check if the protective lens is dirty.
5. Check the red light offset parameter and whether the red light emits light
Thank you for your response
