RDWelder DW-V2Pro, my handheld welder has very weak light output
Miller
My handheld welding machine has been in use for several months now. It uses the RDWelder DW-V2Pro control system. Today, while performing routine operations as usual, I noticed the laser output is very weak. Can anyone help me? Thanks! Where could the problem be?
  • John Trant
    I suggest you investigate the following items:
    1. Check the protective lens, focusing lens, collimating lens, and QBH fiber head for any foreign objects
    2. Whether the welding focusing lens and cleaning focusing lens are installed correctly
    3. Check if the temperature of the graduated tube is abnormal.
    4. Is the galvanometer mirror lens normal
    • Upon inspection, the issue was found to be related to the installation of the focusing lens, which has now been resolved. Thank you for your response.
  • This is most likely a lens issue. Have it inspected or replaced.
    • The installation issue of the focusing lens has been resolved. Thank you
