RDD6616U dual head pressure wheel has abnormal movement
I am using the RDD6616U control system for my device, and today there was an abnormal phenomenon with the movement of the double headed pressure wheel: one end of the pressure wheel is lagging, while the other end is sometimes fast and sometimes slow, resulting in uneven material transportation and affecting the quality of subsequent processing. At first, there was only slight shaking, but as the processing continued, the abnormality gradually intensified and even material displacement occurred. Who can help me analyze the reason?
1. Check the track or bearings of the double headed pressure wheel for dirt, damage, or wear that may prevent the wheel from rotating freely. Cleaning and lubrication can help solve this problem.
2. Check if there is excessive friction between the pressure wheel and other mechanical components, especially if there is wear or deformation, which may cause excessive load and affect movement.1Antworten
Okay, the issue has been resolved
